I've had a 99 996 c-2 for three months now. Last week the horn started honking at will. Then it quit working. A horn would still sound when I locked the doors with the remote. It sounded like a different horn though. I checked the fuse box and found a 25 amp fuse had burned. The manual says it requires a 30 amp fuse. This leads me to believe it has been replaced before. I replaced it with another 25 amp fuse. That made the horn work. However, the horn that sounded when I locked the car no longer worked. Furthermore, after I started the car and drove it, the horn immediately started honking on it's own and then blew the fuse about three minutes later. Now no horns sound. Any help will be appreciated.
Cy Maddox
If you hear a horn beep when you lock the doors that means you have an alarm zone open (or not functioning). This could cause the alarm to trigger.
The alarm system has it's own horn/siren. The alarm system has it's own controller and fuse C3 - and it is 15A.
The fuse B3 is 25A (not 30A) and is for the driving two tone horns - operated from the steering wheel.
Do you have any idea why the fuse would be burning or why the horn honks at will after I start the car with a new fuse?
What fuse blew? Location number please?
Take B3 out and see if it still happens - if it does you have an alarm problem. If it doesn't still happen then you have a two tone horn problem - likely a short in the steering wheel.
It's the B3 that burned. I assume there's a short somewhere. Do I need to pull the steering wheel to confirm that short. If so, it's beginning to sound like something I need to take to a dealer. Thanks
for your time.
Have a look at the thread here. Several methods to fix the problem - you can decide if you want to DIY.
At least the horns work - they are also known to go bad and die too.
Thank you. It looks like that thread will solve my problem. My current problem is that I can't break the torx bolt free. I just reemed the handle of my torx 30 screw driver. The sockets I have won't fit into the hole. Do I have to buy a special torx 30 Porsche tool? I don't want to break or strip the torx bolt.
