I replaced my coolant tank on my 99 996 C2 coupe as instructed in this forum and burped the system when done. Since the replacement, I had a terible coolant eruption that looked like it came from the cap, and I assumed I had not tightened it completely. Several more times since I am suspecting coolant spill and it looks like it is from the cap. I replaced the reservior, sensor and cap with the suggested parts from Sunset, but I am stumped as to what might be going on. Any suggestions would be appreciated. :help:
It is a shame to have such a nice car and be afraid to turn the AC on. :renntech:
Assuming the new tank did not crack when you put it in.
You didn't say that you replaced the cap or not?
What are the last two numbers on the cap part number? If it is 00 then it needs to be replaced.
The new cap has 01 as the last 2 numbers, and there is some dried coolant that looks like it sprayed from the new cap. I wiped it clean and there is more evidence of it leaking. Is it possible to crossthread it? Is there any sense in trying the old cap?
Yeah, if the old cap wasn't leaking then it might be worth a try. I guess you might have a bad new cap?
Should the "00" caps be replaced even if there's no problem with coolant leakage. Does the new cap prevent damage to the reservoir?
Shawn
Dealers were supposed to replace the 00 caps long ago -- but many were missed. The 00 caps are known to leak. The newer 01 caps (usually) don't leak.
I replaced my coolant tank last August and reused the old cap assuming it was the new version. I had to add a little coolant every couple of months until I realized the old cap, orignial 1999, was leaking.
I haven't had any coolant loss in six months since replacing the cap with the latest version.
