I need to re-route all speaker wires to the rear trunk to connect to a new amp which will be placed in the rear trunk. I currently have a "loose install" with the new setup in the front trunk. I need to re-route 8 speaker wires, 3 sets of RCA cables and the Amp power/ground wires. I can put the Amp on either side of the trunk if it will make things any easier. I'm looking for any suggestions or tips, particularly around the engine compartment and rear trunk, as this is my first time with such a project. Thanks in advance.
