I recently purchased a set of high flow cats for the 02 996. When I started to install them I found that the O2 sensors would not connect like the OEM cats. The sensor down stream of the header connects to the same OE location. However the sensor after the cat will now have to hook to the opposite side due to the sensor location in the pipe. The sensor bung on the driver side cat lies directly beneath the passenger side O2 sensor, the reverse for the other side. In effect the muffler side sensors will be crossed. Of course I could splice and lengthen the wires but I'd rather not modify the OE wires.
Any thoughts on this being an issue as the cross is after the cats. Still kind of strange.
