Porsche won't fix my transmission do to the fact that my car was in an accident. It wasn't even a bad one, I was hit ligtly on the rear qtr. But, since I bought the car used, is the reason for not wanting to fix it. The transmission needs a 1st gear sincro. What does that have to do with a light hit on the rear qtr. The accident didn't even cause any structural damage it was just bonddoed and painted. I even took it to a body shop that the service manager told me to and they told me it was just cosmetic, no structural damage.
My question is, what is considered a bad enough accident to void your entire warranty?
Also, I was told that they can not rebuild the transmission it would have to be replaced. Is this true?
2000 996 Aero
For the most part syncro damage is caused by driver error or long term abuse rather than a product defect so I sort of understand why they would be pushing back on a warranty claim. Having said that, their claim that it resulted from a small accident sounds pretty lame. I would keep pushing if I were you. This sounds like one that they might give on.
If you do need a new syncro, you don't need to go through the transmission exchange program. It is my understanding that the gears and syncros are welded on the shafts but there is a shop in CA (I think) that will cut off the gears and weld on new ones for you. A good Porsche shop (not a dealer) should be able to help. Good luck. Jim
