Can you knowlegable guys help me.
I have an intermittant CEL issue.
The codes are P0139 and P1117. The readed i had didnt have useful descriptions.
The CEL started coming on about 3 weeks ago, always at the same place on my drive home in the evening
(about 5 minutes from work, on an approx 50mph expressway)
It would stay on for a day or so and then not show up again for 2-4 days, then the same deal, perhaps 4 times now.
I only just got find a code reader while i still had the CEL on to read the codes
Any advice ?
BTW its a 2001 Carrera4 Cab, 14,000 miles, minor service and MAF replaced approx 6-months ago. No mods (well PSE mufflers installed)
Thanks in advance
Check the wiring on that O2 sensor and/or clean the electrical connections (while it is cool). If that does not cure it you will need a new O2 sensor.
Those codes indicate the heater circuit is failing in that O2 sensor - not that uncommon.
One other quick thing...
Which sensor is P0139 ? Drivers side or passenger side.
Is it the sensor running along the pipe just below the rear bumper ?
Bank 1 is Cylinders 1 - 3 so that would be the left side (driver's side for LHD cars).
There are two O2 sensors for each bank of the engine - one before the cat and one after the cat. You want to inspect/replace the one after the cat (muffler side) on the left side of the engine.
