Simple question that I can't seem to find the answer to. I'm installing new dash speakers in MY99. Right side (passenger) is solid red and red/brown stripe, left side (driver) is solid yellow and yellow/brown stripe. What's freaking me out, is that on one side, the solid goes to the OEM tweeter crossover, and on the other side, the stripe goes to the OEM tweeter crossover (which I'm assuming was the positive - the OEM speaker itself is not marked). Is the wiring the same on both sides, or is it different? Is the stripe or the solid positive, and is it the same on both sides? Thanks, in advance.
The wire with the brown stripe is negative.
Whew! Thanks Loren! I wasted a lot of time looking for such a simple direct answer.
