After searching and reading, including this excellent pcm2 diy post http://www.renntech.org/forums/index.php?showtopic=7068, I'm a bit confused. I have an '03 coupe with the cdr23 which means MOST but would kinda like to have navigation.
Seeing as MOST complicates (ie increases the cost of) aftermarket solutions, I thought that perhaps the factory nav would be compatible with the factory MOST system and might be an acceptable compromise. After reading through the above diy, however, and its mention of retrofitting to pcm2 (analog pre-cursor to MOST?) - I'm not so sure.
Am I missing something obvious and the author of the diy accomplished the very same thing and his parts list .... would be my shopping list?
oh, bugger - just found this thread: http://www.renntech.org/forums/index.php?s...l=pcm2+retrofit
so yep - that diy is exactly what I would need
