I've got a 2002 986 with too much negative camber on the right rear. I found this out after removing the rear wheel to do some thorough cleaning. The inner portion of the tire was down to the threads and belt! I replaced the rear tires with Pilot Sport PS2s Thursday, but can't get in to my Porsche shop for an alignment before next week. Problem is...autoX on Saturday. I don't want to miss it, but I don't want to chew up my PS2s.
Any help would be greatly appreciated.
E
PS the only tools I have are a pair of pliers, toenail clippers and a butter knife.
E
I wouldn't mess with them unless you have a magnetic level and the proper plates to also adjust toe. Changing the camber on the 986 rear will also effect you toe. I would try to find a shop in town or push the dealer to get you on the rack before you abuse the new tires at an autocross.
