Hi
Got a 2000 996 C2, and although I know it has at least half a tank of petrol in it, the gauge and the electronic reading both say it has none at all in, the petrol warning light on the gauge flashing constantly.
Upon ignition, the needle does rise to the true level, but then drops straight away.
Any suggestions of what is causing this, and how to fix it?
Sounds like a bad fuel level sensor.
Any dealer or shop with a PST2 (or PIWIS) tester should be able troubleshoot this down to the faulty component.
In order of least costly to most costly...
Could be just a re-calibration needed.
Could be a bad tank sensor.
Could be a bad cluster.
Until someone does further diagnosis with a PST2 (or PIWIS) you likely won't know know the cause.
