Beru plug gapping
Hi all,
I just installed new Beru OEM plugs as part of my 60K service, and I didn't visually check them before putting them in (it was late, and I was tired - I'd spent a good amount of time fitting the fuel filter!!). Anyway, the car is running fine, but the idle is a little rough. I hooked up my DTC scanner, and sure enough I'm getting a misfire in cylinder 3. I pulled the plug out, and found that the gap on one side must was 0.2mm and the other side was 0.3mm. That's a far cry from the required 0.8mm (I got the plugs from an OPC, so they should have been pre-gapped). The 0.2mm side is virtually touching the centre electrode!
Anyway, I wanted to re-gap the plug, but it's proving difficult to say the least... I can't get the ground electrode to budge at all, and I can't get good leverage because the only thing to lean on is the insulator - which, of course, I don't want to touch.
Do you absolutely need a special tool for these 2-electrode plugs, or is there some sort of trick to do it? As this plug is so far off I'm thinking of pulling all the plugs and re-gapping!
Shash
Well, I've confirmed it's the spark plug... I put one of my old Bosch plugs in (which is still in very good condition), and the erratic idle has gone away! Of course I need to swap that plug again, so I need to get this sorted... I might just get the plug replaced, since it was supposed to be gapped correctly in the first place. Either that or I need to find a proper gapping tool. I don't want to weaken any of the electrodes or insulators - I've seen plugs lose their tops under compression!
So, how often do people get incorrectly gapped plugs from Porsche...? This is my first set direct from the OPC, and already I have one! Just bad luck, or a common occurrence?
Shash
Maybe it was dropped...
Not by me... and none of the boxes looked crushed. Also, both sides are incorrectly gapped - so it would have had to have been dropped twice (or it did some sort of backflip when it dropped to hit both electrodes!).
Shash
I went out and bought the same gapping tool as Jeff and it gaps it fine - although I haven't tried refitting it yet...
cbracer - these plugs are meant to be correctly gapped at 0.8mm - only the 4-electrode type plugs are not meant to be gapped.
Shash
Edited by Rom
We have changed the plugs on several 2.5s with the 2 side electrode plugs, and the 2.7/3.2 Boxster and 996 with 4 side electrodes. I check the gaps on the 2.5 plugs and usually find a few that are offf a little bit. But it is easy to adjust the gap on that type of plug.
The 4 side electrode plug is a different design. There is a gap spec for this type of plug but I have not figured out how you would measure it.
If you slide the wire gauge between the side electrode and the center electrode, won't that be good enough? Although the gap on 4-electrode plugs seems to be pretty huge, so you'd need a big enough wire gauge.
Shash
TP, are you suggesting that the 4-electrode plugs are not recommended for the 2.5L Boxsters? I have been using Bosch Platinum +4 in my 1999 2.5L for 25k miles and I will be changing them in the next 10k miles.
Just curious.
