I need to get to the back of the radio .
Does someone have step by step instructions on how to remove the PCM and center console?
( Hopefully with pictures )
Any help is appreciated, thank you.
I got the small carpeted panels on the side off. Each is held in place with one T-25 screw.
Then there were two screws ( T-20 ) visible at each side panel , which I also removed.
But the panels will not come off .
Does anyone know how to remove them ?
Any help is appreciated .
Thanks.
Thanks.
The panels are held in with small clips. Pull them out towards you but be careful because you can break the clips on the trim piece of you dont pull it out straight enough. After that you've got 4 5mm allen locking tabs and one 7mm set screw.
Thanks.
I did finally succeed a while ago.
Thank you for your reply .
