I have a 2000 C2 Coupe. This morning when I started it up, I started hearing a faint whining / whistling noise at idle. When driving, the whistling lasts till about 3000 RPM and then disappears. The noise is quite prominently heard in the passenger cabin, but not on the outside. I opened the engine cover but still couldn't hear the noise too much. Sit inside and you can hear it clearly.
Any thoughts? Alternator? Belts? It's probably not the fan because I would have heard it with the engine cover open.
Any help is highly appreciated.
