Would I be able to retrofit the Cayenne V6 without Xenon with BiXenon by just buying the headlight assembly or do I need other parts as well. In other words, is it plug and play.
Sorry to say but no, you are talking a large rewiring job, if the dealer did it expect $5k
Another option, without going through the re-wiring hassle is to get a kit that basically includes HID bulbs, ballast, etc and connects directly on the existing wiring. The bulb is H7 size so it is just a matter of disconnecting the existing halogen bulb and connecting the new HID one. Then you connect the ballast to the wire that was going to the halogen bulb. Easy.
Ok you do not get the auto-leveling thing and the HID projector lenses. But is it as bright as the HID and you can do it yourself. :-)
