Still trying to locate my short to +5V... I see a potential source for the short in one of the other DME Connectors (2001 Boxster).
In order to eliminate or rule-in this location I have to either cut the wire or disconnect that whole plug (III/C) at the DME.
Is it okay or is it ill-advised to disconnect one of the harnesses from the DME and do a Key On/Engine Off so that I take a reading with a voltmeter?
