I just bought the car about 3 weeks ago 1999 boxster and was putting in a XM sat system, when I removed the panels around the radio I found these unmarked boxes? One is a rechargable battery the other is just a black box with what appears to be some sort of antenna hookup and a FCC warning label?
I figure its one of two things 1.Car Alarm system or 2. LoJack? They dont look factory so I was wondering of someone could tell me what they are?
Edited by heavyarms
can you take more pictures? I can see telephone power cord...
No this has nothing to do with chickens, Nice try.
The grey box is a rechargable battery pack that is wired to the black box, the black box does not have any useful information on it. It has some numbers and a FCC warning label about freqency interference, there isnt any other useful information. The battery has just normal battery warning info on it and states that it is a rechargable battery pack. Everything was bundled together with velcro and stuck back behind the radio area, I had to pull it out to run some wires.
I was thinking that someone might know what a LoJack unit or the Factory porsche alarm system box looks like and could tell me if this looks like one of them.
thanks.
Can you pull the wires out? The connectors might privide some clues. It could be an FM Modulator but I can't see why it would need a battery pack. If it's a Lojack I wouldn't call it "well hidden"!
I called my local porsche dealer and asked about it, they said that it sounds like the a LoJack unit - this would explain the battery backup.
You are absolutly right, You would think they would try put it in a different place instead of behind the radio. They guy I bought the car from never mentioned a LoJack being installed, I guess I should call him and ask about it.
Thanks for the help folks.
On the contrary - the markings are very useful if you have the FCC label! Check if the unit has the FCC ID - it should be written on the FCC label. It should be of the format:
FCC ID: xxxxxxxxxxx
Just plug the numbers into the first two fields on this form (first 3 chars into first field and remaining chars into second field):
https://gullfoss2.fcc.gov/prod/oet/cf/eas/r...nericSearch.cfm
and hit search. It'll tell you the manufacturer and some other details.
Shash
Edited by Rom
