After attending an autocross event, I now find that when moving slowly and turning while in 1st gear that the sound of the power steering has gotten much louder.
Any ideas?
There was a problem on some MY2000 and newer cars where the power steering return hose could cause noises (TSB 1/00 4895 Power Steering Return Hose -- dated 4-21-00). If the problem is not that hose then it will need to be narrowed down to the pump in the engine compartment or the steering gear in the front.
