Codes P0102, P1128 and P1130 keep coming up. Is the Mass Air Flow sensor at fault?
Any other possible causes?
P0102 Mass Air Flow Sensor – Below Limit
P1128 Oxygen Sensing Adaptation, Idle Range, Bank 1 – Above Limit
P1130 Oxygen Sensing Adaptation, Idle Range, Bank 2 – Above Limit
Potential causes:
P102
– Open circuit
– Short circuit to ground
– Mass air flow sensor
P1128 & P1130
– Incorrect signal from MAF sensor
– Intake air system leaking
– Fuel pressure too low
– Volume supply of fuel pump too low
– Fuel injectors fouled
– Exhaust system leaking
Potential causes:
P102
– Open circuit
P1128 & P1130
Thanks Loren
