Still dealng with my 0453 code... tested the sensor and the wiring and it looks like I am getting voltage on the sensor return wire (should read 0 when sensor is not hooked up).
Can anybody offer any tips or perhaps links on the best approach to locate a short to positive / short to voltage?
Thanks.
Set your multimeter to low ohms. With the car battery and component of the circuit disconnected, probe the circuit at different points until you find the lowest resistance readings between hot and gnd. You will likely be in the area of the short. I used to use this method to find internal shorts in multi-layer circuit boards.
