This just started happening recently with my 2000 carrera cab. Either operated with the key or with the dash switch, on about every other occasion the top will open almost all the way, but then stop about 4" from closed like it hit a wall. Sometimes backing it up to closed and opening again a few times will resolve it, and other times I've found that I can push the hard cover back a touch and it will close. Tonight, neither worked. Any ideas?
Jett
Edited by jett
Do a search for "convertible", you will find a lot of information. To me it sounds like you are short on hydraulic fluid. Look at the DIY, pretty easy to do if you like to do a car work.
