Is unscrewing the oil sending unit hose a bad thing? It is nearly
impossible to get the heater exchange hose through the engine pan
(right of the fan) without moving the o.s.u. hose- however, i feel
this is probably very unwise given it looks as if its never been
touched and is under alot of pressure. There is a build up of grease
along the seals and i am afraid of them cracking because of age. I
also need some sort of metric driver because the hose connects
directly to the engine head- and in an awkward position. Anyone done
this? If this is not feasible, how will i get the hose through the
pan without tearing it? (paper)
marisa draeger
if the hose isn't leaking and you mess with it, it will start leaking. as I remember there were some "fittings" that went in the hose to make going through the pan easier
