I need to remove the roof rail on the left side of my car...The rubber under it has been pushed under the rail and i need to remove it to fix it. I removed the screws where the ski rack mounts and the rail would slide some but it did not want to slide off. Could someone tell me how to remove this without doing any damage to my paint? This is on a 01 996 turbo
Thank You
Jack
The roof rail just pops off and the small plastic clips that hold it on stay in the rail. The covers over the rack atatchemtn points stay on the rail as well. Do a search on the DIY as there is a schematic of the roof rail removed. I just used a soft plactic spatula under one end and it popped off.
I thought you might be interested in reading this web page:
http://www.renntech.org/forums/index.php?act=ST&f=2&t=5942
From,
Brian D. Barrett
Edited by Brian D. Barrett
