I just read the TSB of the PSE pre 02 install and I'm not sure about the way it works!
I know there is switch for opening or closing the bypass valves, but it seems it is speed regulated also?
So I would not be able to open the bypass pipes whenever I want?
Is the post 02 system also working like this ?
I would like to be able to choose to open or cloase the bypass whenever I want, standing in traffic of when I'm drinving, don't want to be restricted!
Is it possible?
And If I don't connect the vacuum hoses the bypass is always open, correct?
thank you
Both versions trigger off of vehicle speed to quiet the exhaust (close the bypass valves) between 30-45 MPH. In the post 02 system you can add a switch that will override that cutout or allow you to have full quiet or loud control. By default the (with no electronics/vacuum installed) the PSE bypass is open (loud).
