Hi, folks. I have a 2002 996C2, 6-speed. While looking under the engine I noticed this part stuck between the rear of the engine block (or maybe a water passage) and the bracket for the exhaust system. The part number is 999 703 478 40. Its material is EPDM. Does anyone have any idea what this part is and where it goes? I have had the car for four months and the engine works and sounds OK - except for a clattering sound just as it approaches 0 RPM when shut off. TIA.
Dan
Dan
It's a vibration bushing used on your air filter box. Someone took the box out and when it was put in, they must have not noticed it came out where the alignment post goes through. The post mates inside the bushing in which sits in a hole under the rear lip of the air filter box. Hope that helps :P
Looks good. One more project for this weekend. Thank you for your response.
As for the slight rattle/clank at engine stop, mine does that too at times and has since I got it a year ago. I don't think it is significant. Anyone else any thoughts?
FWIW, I had the tech's at two different dealerships listen to the engine as it stopped. One tech could not identify the source of the noise. The other said it was a bad or loose muffler mount.
Hi, Wardhog. Yes, that is the correct part. However, when I removed my airbox (which is surprisingly easy to do) There were already two blue grommets installed in the body panel under the air box. They look just like the blue grommet that is under the secureing bolt at the center-rear of the air box.
Speculation: The previous owner or shop removed the air box and lost the black bushings. They then used the blue grommets because they were available. Go figure.
Anyhow, the box fits OK and there are no rattles.
