This has happened for the third time now.
A metallic sounding noise that sounds like things brushing against each other, high pitched, "rotating melody" as the wheel rotates. It was there for a few minutes from what sounds like the driver's side (Australian) rear wheel. It was louder at slow speeds. It went away abruptly when I stopped and put the car in reverse. This was a few days ago.
Today, I heard the same noise after 15 minutes of driving, but in the passenger side rear wheel. It then went away after I stopped and started the car few times.
I thought this might be brake related, but on both sides at the same time? Anyone with similar experiences?
Actually, yeah.. but when i stopped and checked everything i noticed my handbrake slightly pulled, i was sweating blood at that point, so yeah, it was a slightly engaged handbrake :P
Maybe a pebble between the rotor's backside and its protective plate. I get them sometimes and the screech can drive me nuts! No harm, though.
