2000 Boxster S - Can anyone suggest what the answer is to a clonking noise I am getting when using Left lock? Is it a wheel bearing?
Clonking... probably not a bearing in my experience. Make sure the sway bar end links are not loose or worn out. Check by putting the car up on ramps or jack stands, get under, and grab one end of the bar and yank up and down... hard.
Also check lug nuts, check the upper strut nuts, check the spindle clamp nut (which is also the bottom end of the sway bar drop link.)
Also inspect your bushings to make sure there are no tears, etc.
Cheers.
