I have a MY00 with the SSR GT2 rims, they are a 5 spoke open style 3 piece rim. I have a silver car, with color matched rims. I have changed out the side maker lights etc. I was going for that Mono color look.
BUT...
I thought that I might paint the brakes bright red. I think that would really set of the car. Is this DIY project or should I have a shop do it? Next how do I get the Porsche logo back on there. I will do a photo log of this project and post it if anybody can point me in the right dir.
Thank guys
BUT...
Thank guys
This thread has the info you need to do the job - DIY of course.
http://www.renntech.org/forums/index.php?showtopic=6148&hl=
Good luck,
Ed
BUT...
Thank guys
Good luck,
Ed
thanks thats perfect
I just finished painting the calipers on my Boxster, and I would recommend not going the G2 caliper paint route. I tried it, and the calipers looked like absolute crap - there are a few other people on PPBB that had the same results. I stripped that off, and got some hi-temp Duplicolor engine paint. I cleaned the calipers with brake cleaner (take your time with this step, and make sure that the calipers are completely clean). I then sprayed a good coat of the Duplicolor (I used black), let that dry for a day, then sprayed two coats of Duplicolor hi-temp clear coat. I did put caliper decals on after the paint, but before the clear.
My calipers now look they came off a brand new car. It's a lot easier to spray paint on the calipers than to try to brush on the epoxy in an even coat.
Just my two cents.
Edited by steve_wilwerding
I've tried using Duplicolor in the past... You have to make sure you do it very evenly and thinly, per coat. It's a very watery paint so drips very easily (a zero-G environment would be perfect for painting!). Also, make you sure you do ALL coats within one hour. If you have to stop you will have to wait a full 7 days before doing the next coat (ask me how I know! The paint creases almost like magic if you don't!).
I have only used the cheap Duplicolor method so that I know what colour I want though. I will ultimately powder-coat the calipers - which is the ultimate professional method of painting these, and lasts pretty much forever. If you know for sure you want to change the colour, I'd suggest powder-coating them - but it can be a lot more expensive (still cheaper than new calipers though).
Shash
Shash
Hey thanks for the help everybody. If it ever stops raining in Boston I will give it a try. Has anybody had issuse's with the decal's coming off due to heat? Or does the clear coat prevant that?
PR
PR
I don't think this rain is ever going to stop!
A friend of mine North of Boston sprayed his silver recently, decals, clear coat etc. They look great and seem to be holding up just fine. I think he sprayed them on the car but can check if needed, I think he just masked it off and sprayed away.
Chris (North of Boston)
