I was on a Ferrari forum and saw this link for this product called the LiquidVac, a fluid removal system, to do oil changes. You apparently put this tube into your dipstick and siphon all the oil. I checked out the website and apparently it's designed for oil changes. Seems like a good idea. Is this product ok to use on 996's? Here is the link to the company's website: www.liquidvac.com
It seems to have only a 2 gallon capacity - 1+ quart shy of a 996 sump capacity...........plus gravity works just fine.
I use this method on my boat but it alway leaves a bit behind unreachable. You have to go under on your back to change the filter anyway, may as well pull the plug.
Eric
