turbo logo replacement
can someone tell me where i can buy a silver turbo logo and tell me the proper way to replace my current CF turbo logo? i heard a blowdryer, dental floss and some 3m adhesive removal was the way to go...my current CF turbo logo is hard to see :( , so i'm going back to the original look.
thanks in advance!
knef911
As the TT Service manual shows... logo placement is the same "centered" layout as the Carrera 4S.
1. Find the middle of the lid.
2. Position logo Carrera with the dimensions A = 185 mm and B = 31 mm on the rear lid and affix.
3. Position logo S with the dimensions C = 185 mm and B = 29 mm on the rear lid and affix.
4. Insert logo 4 in the external cut opening arrow of the logo S.
Removal is usually dental floss and a heat gun (or warm sun). Clean surface with some 3M adhesive remover and then atach the new logo.
thanks in advance!
knef911
try Sunset or Ebay, and the dental floss.....
S007
thanks in advance!
knef911
Ask Eric at BumperPlugs
http://www.bumperplugs.com/
  • 4 years later...
