Got a P0740 on my '01 Tip Boxster S. Haven't found the right place to get the description. TIA for any help.
Here is what the OBD II manual says for fault P0740:
P0740 - Torque converter clutch, excessive power consumption.
Possible fault cause
- Torque converter clutch not functioning
Loren,
Just got the same code in my 99 996 Tip. Would description be the same?
The car seems to run perfect, and the transmission is smooth as silk. I am a bit perplexed. Thank you
Izzy
Loren,
Izzy
For MY99 Carrera - Tip
P0740 Fault, torque converter clutch - present
Potential causes:
ATF level not OK - ATF supply
Torque converter clutch worn. - Torque converter
Mechanical damage to pressure regulator 4. - Pressure regulator 4 (hydraulic)
Open circuit, short circuit to ground, short circuit - Electrical triggering to pressure regulator 4 to B+. - Hydraulic control unit
Sticking valves.
I would definitely start with fluid level.
