:help: Help!
I have a 1999 C2 with six speed and I’m the process of replacing my cracked oil fill tube. All fine so far but I’m having trouble installed the generator. The workshop manual for installing the oil filler neck says install generator, but it’s not that simple. There must be a trick. I’ve crack a vacuum line already and I’m worried I might do more damage. Any clues would be appreciated.
:help: Help!
It is a little tricky, but it MUST be turned clockwise while removing to clear the fastening eye. Patience and it will come out.
