Just received the PSE I ordered for my '03 C4S. I am having it installed by a non-dealer mechanic and was not planning on having the electronics hooked up. Is there anything special that has to be done to disable the electronic portion of the mufflers to ensure that they are open all the time or are they open by default unless the electronics thell them otherwise. In other words can I simply have thje mufflers installed as-is with no modifications/electronics and have the full sport sound?? Thanks in advance . . .
The PSE valves are open by default. Install the mufflers -- you are done! :D  :D  :D
Well...almost done...you may want to put your stereo up for sale on eBay, since you'll probably not use it anymore... :D :D :D
