Is it possible to add PCM if one is purchased from either the dealer($$$) or a salvage yard ($)? From what I can tell, you relocate the climate control to the lower console as well as the radio...Is the wiring harness already in the dash to add it?
On a 2002 or older you would be better off with Traffic Pro - which gets good reviews.
Porsche does not use a universal wiring harness. Each harness is made according to the options for the car. You would have to compare the wiring diagrams. Jeff
  • 4 weeks later...
apparently this problem only applies to PCM1,
on 2003 and after cars, the PCMII (2) unit is VERY easy to add into the new MOST digital bus system, and requires minimal labor.
