I hear a slight shudder (not too loud) when shifting from first to second in my 2000 996 C2 Coupe. It appears right at the neutral point and feels as if it originiates under the the floor of the cabin. Anyone know what this is? It's really not too loud and one probably can't notice it in traffic or with light music. I don't hear the sound when changing to any other higher gears. It's also not the clutch -- because simply depressing the releasing the clutch in first gear does not make the same sound. Finally, I am making sure that I depress the clutch completely when I shift.
Any help is highly appreciated.
Sounds like it may be the beginning of the end. 996 trannys have a weak 1-2 syncro set. If you search the forum you will find a bunch of posts on it. Don't go back to Porsche, they will try and sell you a whole new tranny. Powerhaus (google it) has a cost effective repair kit.
