Hi everone, hope you are all well.
Just after some help / advice.
I know this is gard to diagnose with out seeing / hearing the car, but wondered if there are any ideas that is might be or any tests I can do.
Basically I am getting a knocking sound from the engine, it only seems to be at idle, and is more evident if you get on the floor and listen from under the car. Its kind of like the knocking noise you get when you start stalling the engine?
Do you have any suggestions?
Many thanks
Russ
Many thanks
Russ
Hi there
can you please tell us which year and what is the milage on your car and it will be better if you could record the sound and post it here
thank you .
Many thanks
Russ
It's been cover few times. Sorry for the bad news.. but it's time for new engine.
http://www.renntech.org/forums/index.php?s...st=entry44208
sorry to hear ur problem .
I think it is time for a new engine or it could be something like lifter .
if you want to make sure post a sound file .however I think with 78K on the clock ,I think it is time for a new engine .
When you say engine rod bearing, do you mean the crack shaft bearing, or the con rod bearing??
Either way, are these not just shall's that can be replaced??
hello there
Just go to my post and see if the problem is the same.
if it sound the same then ur engine is going bad.and it need to be replaced soon.
part 12 is rod bearing and it will crack. easiest way to find out is bring your car to any local auto repair shop and have them drain your engine oil. Look inside of your oil filter if you see any metal debris.. If you have any metal particles, you know.. your engine is going bye bye.
You can have porsche authorized repair shop work on this, but cost of repair is almost same as getting new engine. Porsche lowered price of boxster engine after so many problems with these engines. So they knock out $10,000 off and bring it down to $7000.
so its just the con rod shells wearing out, thats a common fault of most engines, I believe most con-rod shells are made from white metal, which is designed to wear.
Question, maybe laurn or toolpants can help with this one.
Is it a difficult DIY task to drop the engine and replace these yourself??
I can imagine (depending on the engine design) that all you need to do is split the oil sump from the bottom to access the crack shaft, then unbolt each con-rod at the big end (crank shaft end) and fit new shells.
I have done this on other engines before quite easily.
I might even have access to a ramp if that helps?
Any comments guys??
Cheers
