I just changed the MAF in my 98, 2.5 Boxster and....uh...I didn't pay attention (got bad grades in school for that) on the correct postion of the MAF when I took it out. Is there a WRONG way to put it in? I didn't want to remove it and see if it could be put in "reversed". I installed it with the "notch" opening facing the filter. Can anybody please help with this? Thanks.
Edited by bigdog
If you got both screws back in, then you put it in the right way.
It can fit in backwards, but then the screws won't fit.
Todd
