My CEL came on about 3 days ago and this morning I started the car up and it was off! :unsure:
I don't think I have ever had a car where the CEL went off without being reset. Not that I'm complaining...just wanted to know if anyone else has ever experienced this.
Yes... If the condition clears for a period of time or if the battery is disconnected for a few minutes the codes are cleared. I think they are stored in the DME computer and can be read back with a Porsche tester. If the condition has been cleared the light stays off. Watch out for radio code if disconnecting battery( be sure you have it before). I think airbag warning light can not be cleared by disconnecting battery.
There are many sensors that can "blip" into and range that will cause a CEL. If after a few engine cycles, the error does not reoccur, the CEL will go off. A common one is the gas cap not being tight or filling the car with the engine running.
If the fuel system/tank loses the slight vacuum without a refueling the CEL will illuminate until a few drive cycles. Did you open the gas cap but not refuel?
