i noticed a green puddle under my car with dripping on the left exhaust tip. there are many posts on this issue but none mentioning stop leak fluid. Do any of you guys think that any of these "coolant stop leak" products can help the situation as a temporary fix. or would it be better to go get the system pressure tested and repair the defect.
peace
umar
99 c2
IMHO - I would never use a stop leak product on a Porsche. The last thing you would want on your expensive engine is a port in the block sealed.
Chances are you have a leaking coolant tank and/or cap. There is a DIY in the 996 DIY forum.
