all german parts sells textar pads which they say are oem -so are the same as the textar pads sold in that porsche box from sunset ? thanks, larry
They should be :-)
Only thing you may need to watch out for is the wear sensor - it may not be drilled on the textar pad.
Just replaced mine. I used Sebro discs (rotors) and Textar pads. The Textar pads had the wear sensor holes already drilled in them.
