For the last couple of months, my passenger side window hasn't worked at all, it was rolled all the way up and wouldn't roll down. Once before then it worked and it rolled down and up but then it stopped again. Then yesterday, my instructor at autocross just rolled it down totally fine. Now it's stuck all the way down, and won't roll back up. I would imagine that the motor is fine, because it occasionally (such as yesterday) works, so I think it's an electrical problem. Also, the switch on the driver's side doesn't work either (for the passenger side window only, driver's window is fine). Any ideas?
-Cody
  • 4 weeks later...
what if any diagnostics have you done? have you measured power at the switch? have you measured whether power is getting to the motor? have you checked to see if the wires that go into the door have broken? any of these could be a cause, but with no information besides "it doesn't work", it will be hard to help. I'd suspect broken wires, but I'd strongly suggest you trobleshoot systematically
  • 3 years later...
-Cody
Try to check the plug on the passenger window electric switch. Remove it and spray the contacts with conduct cleaner spray.
Hope this works
