2002 996 cab w/26000 miles. Green indicator will light in dash when stalk button depressed but none of the functions on the stalk will work. Any ideas?
Make sure all the brake lights work and are of the OEM specified incandescent type including the high mounted one(s). When I put a led light in the high mount light the cruise would not work until I added a load resistor.
Thank you, I'll double check all that.
