I’ve had my '03 Boxster for a little over a year. When I go over bumps, small potholes, or rough bridge expansion joints WITH MY windows up-- my driver’s side door makes a heavy sounding thud.
An area dealer told me they could not recreate the thud- but they did lubricate the top, which seemed to make it a little better-- or at least I tried to think so. The thud never completely stopped, but now it is getting a lot worse. I’ve done searches on all the boards and checked all the TSBs and haven’t found an answer.
It only happens when the window is all the way up. If I crack the window- even a small bit- the thud will not occur.
I would really like to go to the dealer with some ideas for fixing this. Any theories that might help would be appreciated. Many Thanks
My 2000 does exactly the same thing, although I've thought the thud/rattle was in the top and not the door. A solution would be great.
