Could not find it at Tirerack, Pirelli P Zero Assimetrico
size 255 40 17
need to replace one and want to match the opposite one,
I tirerack dont have it then it is, I'm in the same boat, i need front tires Potenza S-02's theyre also
discontinued <_<
Used the Pirelli website to locate some dealers, called 4 and all said that they do not have it. The tire is replaced by the Asimmetrico Rosso. So I've got to replace 2 rears, not one.
This brings up a point, does the rear right wer more than the rear left? Is the limited slip diff. if the boxster has one?
Try looking on that auction site. I had the same problem and found that exact tire with similar wear to my "good" one for less that $50. After changing the tire, I flipped the tires side to side every 3000 miles or so and they wore prett evenly.
