Just wanted to know what is the max spacer size i can use for the rear wheels with 295 tyres?
What about the front sizes too?
Help would be appreciated.
Samvit
Samvit
I don't know how aggressive you want to be. I put 6mm all around with my stock 285s using 38mm bolts. Mine is an 02 narrowbody.
I have 18"X11" rear wheels with 295's and 45 mm offset on a wide body '02 with 6.5 mm spacers and longer bolts. looks good. Same on front . I would not go any farther out than this though. If I lower the car I will probably have to remove the spacers as the large fender lip might hit rubber?
Eric
I have 18mm each side on the rear, with 285 30 18 10" Sport Designs
Front has 7mm each side, with 8" x 18" wheels
Car is a C2 2002 with X74 suspension.
No rubbing at all.
David
