Hi
Anyone got any instructions on how to remove the rear bumper on a 996 03 model?
Cheers,
Tim
Took mine off last week to help with install of GHL mufflers.
I have a C4S so I am not sure if yours will be exactly the same.
Remove the bumper rubber blocks ( hex wrench from the little door under them) you don't have to remove the screws , just loosen them a couple of turns.
Remove the 4 phillips screws on top under the engine hood.
Remove the 2 phillips screws between the tips
Remove the 2 screws on each side on the bottom 9 torx heads.
Remove the 2 screws on each side under the fender ( right at the top ) These are a larger torx size . When I reached these ones the car was on jack stands at the back with the rear wheels off so I don't know if they can be reached with wheels on.
Remove the 1 screw on each side under the front most top of the bumper ( they are a bit hidden ). I think there are a couple of flat washers on these ones.
Pull the sides of the bumper out a bit and then stand at the back and pull it off. It is quite flimsy so be careful with it.
I put mine back on by myself but it would have been much easier to do it with a helper as it is quite floppy.
Eric
Attached is a pdf that another member sent me
the line that says: Remove the 2 screws on each side on the bottom 9 torx heads.
Should have said Remove the 2 screws on each side on the bottom (torx heads).
Eric
(edit - attachment removed as it was copyrighted material - Loren)
Edited by Loren
