I have a 1997 Boxster with stock heated seats. they have started to act up lately.
When I switch them on they no longer come on, if I drive around for a while they will work.
Could this be a relay problem and if so, where is the relay located.
The relay tray is above the fuse box.
The yellow line goes to the relay for the seats - it is the socket numbered 18 but you are no going to be able to see the numbers unless you pull the tray out.
The 4 relays just to the right are for the radiator fans. Those 4 relays are identical to the seat relay. So swap 1 of the fan relays for the seat relay and you will have your answer. Jeff
