Hello,
I have a 986 porsche 2001 and i been having a problem with the roof retracting. The motor lifts the back spoiler but the roof doesnt go down by itself, you manually have to push it down. I noticed the Part no. 986.561.279.02 Transmission Pivot/Push Rod is broken. Before i replace it, do you know if this is the part that retracts the top? or could it be something else?
I just replaced the same item. I am sure this is your problem. I got many different quotes for the new piece. Suncoast quoted $45, local dealers were anywhere from $66-$79. The updated piece has a white ball on the end rather than red. Hope this helps.
coachb
1997 986
