I was inspecting the underside of my 01 S and noticed a very small quantity of oil dripping on the plastic undertray, about 2 inches from its rear edge. It doesn't end up on the garage floor because it is retaind by the undertray.
There is an hexagonal bolt at the bottom of the engine, in a diagonal position (I don't know what it does), and the oil is either dripping from that spot or from somewhere above and reaches the bolt which is at the lowest point of the engine.
Any ideas as to the possible sources of the oil leak will be well appreciated.
