I hooked up the TrafficPro model 4773 to the two connectors that came off the prior CDR 220. Only thing that doesn't work are the speakers. Seems this has been discovered and I guess a wire has to be 'moved from Connector A pin 5 to Connector C1 pin 6.
What is the best way to do this? Can I just solder a wire between the two wires or must I cut the wire going to the connector A and then solder to C1 pin 6
What I'm trying to find out is it OK to leave the original wires intact and just connect the two with a 'jumper'?
:help:
Joe
:help:
Joe
Hi Joe,
I went from CDR22 to Traffic Pro Highspeed on my 99 C4 (no Bose but amp) and the way you described it is exactly how it's done. Just jumper the two wires and the amp should be supplied with power. No need to disconnect anything prior to that.
I guess right now you can SEE everything working fine and the bars will move when you adjust the volume but no sound at all!?
Thorsten
Thanks guys,
I just put a jumper between the two pins and voila...... sweet music!!
Put the TrafficPro back in the dash and the A/C control unit and trim piece.
Now enjoying a beer with a little grin on my face.
The fit of the two top screws on the side guides for the A/C controls (which were moved from the lower console with a console delete installed) seemed a little sloppy. I believe I read somewhere that this was a problem for someone else. If anyone can direct me to that post I would appreciate it.
Thanks again for all the help.
Joe
Did the same about 2 years ago. You dont need to cut and solder. A jumper works fine.
Thanks guys,
You're welcome. There's nothing sweeter than the feeling of successfully completing a mod on your car. Especially if a cold beer is waiting :clapping:
Edited by toddel68
One of the best solutions to get a navi radio CD is to install the new Becker Indianapolis Pro. It's provided with a bluetooth telephone hand free system, and besides can reproduce MP3. It has an ipod connection too. The design is the same as Porsche radios (made by Becker)
Edited by juankimalo
This can't be used for the United States though, right?
I didn't know :(
Sorry , I'm always thinking about an european :unsure:
  • 4 weeks later...
Other than the earlier Becker units like the Traffic Pro Highspeed the display of the Indy cannot be inverted to match the Porsche display (dark background, highlighted letters).
Thus it's not really a perfect fit. So Becker saved 20 cents on the display and I'm not upgrading BT telephone and Ipod :-(
Thorsten
Thorsten
May be but this is not a very important stuff to me.
Thorsten
Well it was you who said the design was the same as the factory radio which is not true. There may be others who want the perfect match.
Thorsten
