PCM Navigation stopped working....HELP!
Hi All,
I've just removed my PCM unit (various reasons....) and put it back in. Everything is working fine, except the map continues to show me at the same place.
Would the navigation have been disabled some how? COuld I have blown a fuse? Help need please before I have to open my wallet to Porsche!!
Cheers,
Tim
I assume you are sure that you reconnected all the cables in the back of the unit?
Have you tried removing the map CD and then putting it back and reloading the maps with the Map button?
If after 5 minutes there is still no map displayed (or it is still frozen), then the complete system must be shut down as follows:
1. Remove ignition key. Leave the vehicle, lock it with the hand-held transmitter (or vehicle key) and leave it locked for at least 5 minutes.
2. Unlock the vehicle with the hand-held transmitter (or vehicle key).
3. Then repeat the map loading startup process.
Loren - You're a star. Yes, it worked thanks. Just needed to leave it off to reset itself.
Cheers,
Tim
